No power, check engine light on when i get on the highway
Old Aug 6, 2003 | 09:37 PM
MTchevy1's Avatar
Car: 94 s10, 97 s10
Engine: 383cid, 350cid
Transmission: 4L60, NV3500
Axle/Gears: 3.73, 4.10
I just finished putting a fresh 305 in my RS. The mods are an LT1 cam, open element filter, hedman headers/y pipe, and lower temp fan switch (if that even counts as a mod). I have my timing set at 7* btdc. It runs strong around town...but when I'm on the highway for about 10 minutes, the service engine soon light comes on. It stays on until I park the car for a while. I don't notice any difference right away when it comes on, but when I get off the highway I have no power whatsoever. Has anyone had, or recognize, this problem? Any recommendations would be really appreciated.
Old Aug 6, 2003 | 10:18 PM
Merlin's Avatar
Scan for error codes. My first guess is that you'll find at least a "32".
Old Aug 7, 2003 | 06:45 PM
MTchevy1's Avatar
Car: 94 s10, 97 s10
Will you please tell me what a code 32 is? Also, does OBD1 store intermittent codes? I can't remember if it's only OBD2 that does that.
Old Aug 7, 2003 | 07:34 PM
Merlin's Avatar
A '32' is an EGR system fault. GM's OBD ECMs store error codes for the last 50 engine run cycles. There is no such thing as a "pending" DTC in the older ECMs - it's either a fault, or it isn't.
BRoss99
Aug 10, 2025 05:08 PM
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
