which block/engine is this
Old Aug 9, 2003 | 05:43 PM
Air21's Avatar
stamped on the bellhousing ...
10046164
CANADA
GM 5.0LG
On the front by the head
K0489560
I was told it was a 350 but it isnt looking that way, it also has all the smog stuff on it, pump, lines and what not....
Old Aug 9, 2003 | 06:05 PM
ede's Avatar
ede
try www.mortec.com
Old Aug 9, 2003 | 06:12 PM
Air21's Avatar
i did, this block is an odd ball, i think its just a 305 that someone put the TPI intake on from a 350.
Old Aug 9, 2003 | 06:48 PM
83crossfireZ28's Avatar
"GM 5.0LG "
newer blocks have the size stamped on them like that...
i hope you werent buying it from someone as a 350, because it is a 305...
305 = 5.0L (L for liters)
350 = 5.7L
etc etc
it IS a 305 tho
Old Aug 10, 2003 | 01:42 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
yep def a 305 unless gm made a stamping error..pretty sure the 5.0l and 5.7l are cast in there though.. woulda had to somehow have a bad mold or somethin to cast a 350 with 5.0l stamped on it.. but hey stranger things have happened.. if your really in doubt pull the heads and measure the bore.. im pretty sure your gonna find out its a 305 however
Old Aug 10, 2003 | 02:58 PM
Air21's Avatar
its an oddball casting number, cant find it in any of the online guides.
Old Aug 10, 2003 | 03:59 PM
Air21's Avatar
are the water pumps the same as a 350 and 305?
Old Aug 10, 2003 | 04:32 PM
89RsPower!'s Avatar
yep, assuming its using the same belt configuration, some newer sbcs with serp belts use reverse flow pumps
Old Aug 10, 2003 | 05:43 PM
Air21's Avatar
would they use different head gaskets as well? since the bore sizing is different?
Holland
Dec 16, 2000 03:25 PM
