which would make more power on a 305...
Old Oct 26, 2000 | 04:58 PM
black84ta's Avatar
aluminum l98's or vortec's? also which intake would work good with the l98's?
Old Oct 26, 2000 | 08:11 PM
ede's Avatar
ede
i wouldn't put any 350 heads on a 305. find a good set of heads made for a 305 and use them.
-=ICON MOTORSPORTS=-
Old Oct 26, 2000 | 08:18 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
The vortec's would probably make more power in the end...but you've got to get some machining to keep your compression from going to hell. Look into either a torker II or a Performer RPM if you decide to go with the L98s.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Oct 26, 2000 | 10:13 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
The Aluminum L98s will bolt right on with the 58cc chambers and not drop compression. Big plus. The AL L98s are the perfect 305 heads out of the box IMO (and that's all I like them for, they don't flow well enough to be a kickass 350 head. relatively stock that is).
The vortecs will flow more and make more power, but you'll want to have them shaved and run a thinner head gasket to retain some of the compression. Otherwise you'll be way down on comp... The Vortecs are cheaper too(assuming both set of heads are new anyway), so cost wise you might still come out about the same after the milling vs the L98s.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited October 26, 2000).]
jaridjohn
Jul 8, 2024 03:49 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Sep 17, 2020 08:26 AM
86White_T/A305
Aug 17, 2015 12:16 AM
novaderrik
Aug 10, 2015 12:44 PM
