V6 Alternator = V8 Alternator?
Old Aug 11, 2003 | 10:21 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
I started up my IROC today only to find that my engine is making a constant whine that changes with engine speed. I listened around with a pipe and think that the sound is comming from the alternator. Also, I found that the alternator was too hot to touch (even for a second) after only a couple of minutes of running time--and I don't think they're supposed to get that hot that quickly.
Anyway, I don't really have money for a new alternator right now, but I'm not driving my '88 Camaro (with the 2.8L V6).
Could I take the alternator from my '88 Camaro and put it into my IROC (L98)?
Old Aug 12, 2003 | 12:06 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
yes you can, but you'll have to swap casings, because I believe your 2.8 alternator mounts in a different location. Once you swap the casings, you should be good to go, that will hold you over for a while.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
