smells like gas
Old Oct 27, 2000 | 04:48 PM
85camaroz28's Avatar
smells like gas
i just bought an 85 z28, it is in good shape all but it really smells like gas when i am dring. what could that be? please help.
mike
Old Oct 27, 2000 | 04:58 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
First, don't smoke in your car. Next, TRY to find out WHERE the smell is coming from. It could be a lose gas line, filter, hole in your tank, etc.
A very common problem is the gas filler neck. On many F-body cars, there was a recall on it. Depending on the car model, when it was made, etc, it MAY be covered by warranty.
But try to figure out where the smell is the strongest. If it is the rear, check out the gas filler neck.
Old Oct 27, 2000 | 06:16 PM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
Just something simple if you haven't already
checked is the gas cap itself I had the same
problem and a new cap stopped the smell
TPIS airfoil,relocated MAT,AFPR,TB h2o bypass
otherwise stock 5.0TPI
Old Oct 27, 2000 | 07:49 PM
thats what i thought it might be. but did yours only smell when you were driving or could you smell it when you haven't drove it in a while.
Old Oct 27, 2000 | 10:26 PM
MY87ROC's Avatar
Car: 87 IROC
Engine: 5.0
i smelled it when driving and mostly when stopped at a light for a while and also in my garage when it was hotter out being i am in vegas it was pretty hot. since i got a new gas cap i haven't smelled gas anymore
Old Oct 29, 2000 | 11:40 PM
i found the leak, it was the bolt that conected the gas line into the carborator was lose because the gasket was worn away. it was pretty simple to fix. only cost 20cents of a new gasket and took 10mins. so it was nothing major.
thanks for the info though
Old Oct 30, 2000 | 09:51 AM
Car: Death Mobile
Engine: 666 c.i.
Glad to hear that you found it and good thing too. Leaking gas around the engine is not a good thing.
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
