Car stalls at idle after installing new plugs and wires
Old Aug 12, 2003 | 10:35 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Hey guys,
I had my uncle replace my stock spark plugs/wires with some Accel U-Groove Plugs and SuperStock 8mm wires. He put them in and started the car up. It runs fine at engine speeds above idle, but if I let it sit on its own in gear, it will stall within a minute. But on the highway it runs fine without any noticeable loss in power. My question is, what is causing this stalling? We accidently knocked out the vacuum line from the brakes to the engine, but reconnected it, is there air in there that is bad or something? Or perhaps my uncle did not gap the plugs (I think he did I am not sure). I also checked all connetions and they are secure, as well as the distributor, which does not rotate(might throw off timing) Any help is greatly appreciated, I dont want to mess up my car as I will be still driving it around with it stalling.
Old Aug 12, 2003 | 11:19 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I'm guessing maybe the plugs aren't gapped right...but I'm not sure that I've ever heard of improperly gapped plugs causing stalling. The plugs and wires should if anything make the car idle better not worse.
What's the idle rpms at? Checked fuel pressure? Sure all the vacuum lines are connected properly? Have you thrown a timing light on it just to doublecheck? It doesn't backfire or miss during acceleration, not free-revving, does it?
Old Aug 12, 2003 | 11:38 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Sounds like the timing is off.
Old Aug 13, 2003 | 09:08 AM
It does not backfire, the vacuum lines all check out okay. The problem is, how could the timing have been knocked off? The distributor bolt is as tight as can be, should I try to reset my computer?
Old Aug 13, 2003 | 09:31 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Don't take this the wrong way but make sure the wires were put on in the correct order and on the same posts as before. If they are in the correct order but one post off then your base timing be off by 12.5º
specialized
Jun 18, 2022 09:26 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Brcharrelson
Aug 26, 2015 07:47 PM
Exxon Limited
Aug 9, 2015 08:13 PM
92projectcamaro
Aug 6, 2015 01:20 PM
