can I use a 350 crank in a 305?
Old Aug 13, 2003 | 10:27 AM
stupid4901's Avatar
I need a forged light-weight crank for my next build up, but I havent seen much supprort for the 305. Are there any places to get them or can I just modify my block to use a 350?
Old Aug 13, 2003 | 10:53 AM
ede's Avatar
ede
physically it's fit, the same pins, mains, and stroke. you may run into a issue with balance but that's nothing a machine shop couldn't fix
Old Aug 15, 2003 | 08:46 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
If you use the 305 rods with the 305 crank, and use lightweight pistons, (and have it all balanced) you will end up with a lighter, but somewhat weaker, bottom end. This would help you in the acceleration department if you didn't get too carried away with making power. Otherwise, go with the 350 crank, it's balance weight is considerably different than the 305, and even though a machine shop could balance it, it would take a lot of mallory metal to do it.
Old Aug 15, 2003 | 10:28 PM
trans92's Avatar
Car: 1992 Trans AM
Engine: LB9 305 TPI
Transmission: 4L60
I tried doing that 2, but the problem I had was tremondous loss of gas mileage and good gain in performance. However I wasn't impressed with it since I lost 5 miles to the gallon. I actually had to reprogram my chip to gain more gas mileage
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
st.evel07
Aug 13, 2015 06:15 PM
BBSDesigns
Aug 11, 2015 07:39 PM
