Broken Alternator mount..help
Old Aug 13, 2003 | 12:46 PM
uk89camaro's Avatar
As you can see from the picture, the ally engine piece that the alternator mounts to snapped off. (Due to a non standard replacement alt. that obviously put a lot of strain on the bracket, hence snapping it. FYI, the non std. alt. was fitted by a breakdown truck a million miles from home, and it got home, then this happened).
Questions : Can the broken piece be reliable if welded back on?
If not, what is the name/part number, of the whole piece that needs to be replaced.
p.s. Being in the UK, it's very unlikely that the few junk yards we have will allow that piece to be removed from a donor motor. They're generally all sold as a complete second hand engine unit.
It's an '89 305 TBI LO3 Camaro. (And no, I don't want to swap the motor )
Thanks.
Old Aug 14, 2003 | 06:54 AM
uk89camaro's Avatar
ttt
Old Aug 14, 2003 | 07:40 AM
ede's Avatar
ede
instead of trying to weld the broken piece back on i'd build the piece back up out of all weld metal and then drill a new hole. if that isn't what you'd like then the broken piece can be welded back on, id fit the piece and tack it on each side then grind a groove in one side and weld it and repete for the other side. you'd want 100% pepetration or close to it, that's why i'd just build it up.
Old Aug 14, 2003 | 08:55 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If time is available, search the classifieds...I see many ads that would have what you're looking for.
Old Aug 14, 2003 | 09:11 AM
Vader's Avatar
Ed's suggestion needs no further explanation, just an addendum. Since shipping the bracket off to him might be cost-prohibitive, you might try finding a place that specializes in boat propeller (screw) repairs. They usually have a lot of aluminum alloy experience, and replace entire missing blades just as Ed describes. If you really strike out on getting that repaired, try to get in touch with Si_Camaro in Nottingham. He seems to have a line on ThirdGen parts.
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
