trying to improve torque, non 3rd gen
Old Aug 14, 2003 | 10:08 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
Hey everyone, I have a 1995 Chev ext cab truck with the 350 and 5 speed trans, Im trying to improve torque for towing but keep all the TBI stuff on it, I was thinking of a Vortech head swap but it seems I need a different intake?? Im currently in the planning stage right now. It is all bone stock right now.
TIA
Jack
Old Aug 14, 2003 | 10:50 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
ANd..... the problem is......????..
Old Aug 14, 2003 | 12:03 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
More torque for towing? OK.
I would use Vortec heads (12558060) and Vortec-TBI intake (12496821).
To keep it emissons legal, you'll need a way to route exhaust gas to the intake manifold. See following note:
"Technical Note: To use EGR, the gasses must be plumbed from the exhaust manifold into the intake manifold. Many exhaust manifolds have drilled and tapped holes that can be used to fabricate a tube. An example is the 1996 and later pickup truck with RPOL31 350 engine, which uses exhaust manifold P/N 12557828, EGR pipe P/N 10220275, and fitting P/N 12552329. That combination will fit this manifold for late model pickup trucks. Vacuum controlled EGR valve P/N 17113457 and gasket P/N 12337972 can be used on some models."
I solved this problem by purchasing headers with AIR tubes and instead of injecting air into one, I draw ehaust gas from it and route it into the intake manifold, so I can stay emissions legal.
Further, I would contact Comp Cams camhelp@compcams.com and tell them your application and ask them to recommend a cam for you. I could expand here, but take it from the people that deal with this stuff everyday and then make your own choice.
On the vortec heads, if going for more than ~0.430 lift, you'll need new springs (Comp Cams 981-16).
I did this on my 91 RS TBI Camaro with decent results.
Best-
S-D
Old Aug 14, 2003 | 12:17 PM
demonchild's Avatar
good post swerve-driver...however, you could just buy the edelbrock tpi replacement unit and gain a little help in the towing.
http://www.edelbrock.com/automotive/mpfi_tbi_intro.html
Old Aug 14, 2003 | 12:33 PM
Car: 1991 RS
Thanks,
That is a nice setup- just depends on what a person is willing to spend I guess. I've been pretty impressed with the power that comes from the vortec heads and, having suffered with the stock LO3 heads, would try to ditch them at first chance. I imagine monte-ss has the LO5s on his rig, but I'm betting they're not all that much better than the LO3s.
S-D
Old Aug 14, 2003 | 11:04 PM
monte-ss's Avatar
thanks guys, yeah I guess I left the part out of what I was wanting to do, Im just looking for ideas to increase mainly towing on the truck yes it is the bone stock LO5 K engine code, I dont want to make it some outrageous hotrod just a good driver gets decent fuel economy and can easily trailer my monte.
thanks
Old Aug 15, 2003 | 03:43 AM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
A good way to increase torque is to turbocharge the engine. As a turbo uses the exhaust gasses, it would also help with the emmisions. A little expensive though!
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
