Shifter Indicator
Old Aug 14, 2003 | 10:50 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
Shifter Indicator
On my 700-R4, my stock shifter indicator reads
P R N OD D 2 1
My question is that what is the difference between mine and lets say
P R N D 3 2 1
Is there a way where I can change it to P R N D 3 2 1?????
Old Aug 14, 2003 | 11:31 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
On the 700-R4s D is 3rd. So only the lettering is different. I guess you can just make up a template to go in the shifter plate to use instead of your stock one, so it will say 3 instead of D. I see no reason though.
Old Aug 15, 2003 | 12:39 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Re: Shifter Indicator
P R N OD D 2 1
P R N D 3 2 1
You could change it to whatever you want I suppose, just as long as you don't forget when gear you are really in
The simple answer is that the only difference is the letters/numbers.
The [D] on your shifter is 3rd gear and [OD] is 4th.
The [D] on their shifter is 4th gear
Old Aug 15, 2003 | 07:50 AM
Vader's Avatar
Odd that they would change languages part way through the order like that - " One, Two, Drei," etc. You might also find a "G" on the accelerator pedal for "Germulicheit".
Is "R" still for "Race?"
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
