Klunking noise
Old Aug 17, 2003 | 08:13 PM
Acidtalons's Avatar
Klunking noise
I have 1986 Z28 Camaro with 1" Lowering springs, and when I go over a large bumps or roughly paved surfaced I hear a loud klunking sound from my front drivers side wheel well.
I pulled the front driver's side tire to see if anything looked out of place, everything looked fine, no signs of metal to metal contact. I bought the car used and don't know the age of the shocks, though when I had the front suspension apart they still seemed pretty good. Any ideas?
P.S. I posted this in the suspension forum and got no responses.
Old Aug 17, 2003 | 09:04 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
did you check the swaybar endlinks? I know you said you checked for metal to metal. also check you lower ball joint.
Old Aug 17, 2003 | 09:05 PM
Acidtalons's Avatar
Sway bar endlinks and Ball joint are brand new, but they both checked out okay.
Old Aug 18, 2003 | 01:22 AM
Acidtalons's Avatar
TTT
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
