when should u change your pcv?
Old Aug 17, 2003 | 10:13 PM
icebird_1981's Avatar
how do u no if u need to replace your PCV valve?
Old Aug 17, 2003 | 10:29 PM
ChevTech84's Avatar
I change mine when I got the extra five bucks to do it, but most folks probably never change it until you get oil pouring out of the dip stick tube from built up crank case pressure.
Old Aug 17, 2003 | 10:37 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Some may (and probably will) say otherwise, but a rule I learned about them is, as long as they rattle when shaken (ie. not clogged or carboned up) they are fine. Of course preventative maintenance doesn't hurt...
Pete
Old Aug 17, 2003 | 10:59 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Theyre so cheap id just pick something you have to do at semi-regular intervals (some form of fluid change or something) and just do it regularly even if it doesnt really need it....better safe then sorry
Old Aug 19, 2003 | 12:01 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep; I change mine out once a year, part of the major tuneup... for something that cheap, might as well change it and forget about it.
Old Aug 27, 2003 | 12:16 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
I worked in lube shops for over 2 years as management, and now work at a buick dealership and have learned the PCV valve are recommended to be changed every 10k-12k miles, normally when you change the air filter.
Old Aug 29, 2003 | 01:03 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
where is the pcv valve and what does it do?
it sounds easy to replace, mine hasnt been fiddled with for a long while so i want to replace it.
i dont care if i ask stupid questions as long as i dont get stupid answers
Old Aug 29, 2003 | 01:35 PM
Vader's Avatar
Some of you may have already read the long, tedious story I have about significant problems with aftermarket PCV valves. Suffice it to say that I generally clean the PCV valve and inspect or replace the tubing at least once a year. If you cannot clean you valve to your satisfaction, at the very least, replace it with ONLY a genuine factory part - especially on speed-density EFI engines, like later TPIs, MPFIs, and TBIs. Air flow calibration through the PCV is critical to the SD systems' presumptions about intake air at a given MAP and TPS. Factory units are actually flow-tested in production (I worked for a company that made them for GM).
Old Aug 29, 2003 | 01:49 PM
Morley's Avatar
Ditto.
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 20, 2015 11:08 PM
BAMiller
Sep 14, 2015 06:38 PM
z28guy134
Sep 1, 2015 11:50 PM
