Engine disassembly help
Old Aug 18, 2003 | 06:54 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
Hey all, newbie here again. What is the best way To remove the pistons from the bore. Through the top or through the bottom? I am sending this engine out to the machine shop on Friday and would like to not break anything. I am sending the crank to the shop as well, so do I leave it installed? Or carry it separate? Thanks all..
Bill
Old Aug 18, 2003 | 06:59 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Pistons out the top...not even sure they'll come out the bottom.
If you have any ring groove, best to remove it first
I'd suggest just taking the whole thing into them as-is.
Old Aug 18, 2003 | 07:14 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
Yup, out the top, feel for a ridge, remove if deep. The usual, attach small hoses to rod bolts. As for leaving the disassembly for the shop, ask about cost. Nobody does anything for nothing but might be worth the cost if unsure.
Old Aug 19, 2003 | 05:07 AM
groundrat's Avatar
Car: 91Z28
Thanks for the info. Also If I have to get the block bored over, how hard is it to swap the piston rods to new pistons?
Old Aug 19, 2003 | 05:20 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Most likely you have press pin pistons. It's very difficult to remove the pins without breaking the piston without the right equipment. I left mine for the machine shop to swap.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
