Open Air Mods?????
Old Nov 2, 2000 | 01:31 PM
BLUE92RS's Avatar
Open Air Mods?????
When you install the open air on the rs and take of the stock air filter holder with the snorkel, Underneath all that is like two plug things (Sorry dont no much about cars) i belive this to be the throttle body. Whatever it is does the open air just sit on the top and hookup without any mods?
Old Nov 2, 2000 | 01:55 PM
Mo's Avatar
Mo
It's been awhile since I've looked at a TBI but let me see if I can figure it out... in the middle of the throttle body there are two injectors i think each with a cone type shape underneath it. If you get a non drop base open air filter holder, you can take off that gold colored ring and sit the filter assembly right on the throttle body, there may be a gasket or something,not sure though, and then what I did was put a hole in the new air cleaner for the IAT sensor. I think you also need to plug a vacuum line
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
Brinkkl2000
Aug 4, 2018 08:29 AM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
mdtoren
Aug 23, 2015 12:52 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
