Clakity Clak! NOISE__Valve lash??!?!
Old Aug 20, 2003 | 04:42 AM
TBIfly's Avatar
LG4-84 Berlinetta
From the moment I start up the car, there is an audible "Clakity clak clak clak clak clak calkity clakity clakity clakity clak clakity clak clak" coming from the engine. I thought it may be my rocker arms/lifters knocking. What could this sound be?
Sound:
-happens in idle, as explained
-increases with rpm
Any help is greatly appreciated!
My brother said it is rod knock, which means a helluva bunch more work.
Tonite, I removed both valve covers and listened for the noise, it seems to be coming from the 2, 4, 6, 8 cylinders...somewhere near there. I tinkered with it a bit by tightening each rocker arm 1/4 in at a time, 2 times each...sound is still the same.....have any idea?
Old Aug 20, 2003 | 11:50 AM
TBIfly's Avatar
bump
Old Aug 20, 2003 | 12:13 PM
demonchild's Avatar
could you be mistaking the noise for an exhaust leak?
Old Aug 20, 2003 | 12:34 PM
TBIfly's Avatar
This is definitely not an exhaust leak, of that i am certain.
I was thinking it was what i described earlier, rod knock, or bolts on the engine mounts.....which i doubt. The sound is very irrhythmic.
Old Aug 20, 2003 | 03:57 PM
stupid4901's Avatar
Yeah it sounds like rocker arms. I've been listening to that sound for the past week because my stupid cam won't work and the valves are all messed up.
Old Aug 20, 2003 | 04:14 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
how many miles are on this thing. i had a 350 that had about 150000 miles on it and the rings werent replaced with the rebuild and i ended up with piston slap. it sounds like a very rapid clackin noise.
Old Aug 20, 2003 | 05:39 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
sounds like ur lifters may me clicking,how your oil presure? my v6 did that for a whle,i ran a can of liquid wrench in the oilfor 15 minutes,then changed the oil,went away.
Old Aug 20, 2003 | 07:00 PM
TBIfly's Avatar
This is the original engine as it was bought in 83. I doubt there has been anywork done to the engine but a replaced valve cover gasket i found out.
I may shoot for the liquid wrench idea as well. Id hate to think its worn rings because that work is beyong my scope of knowledge and financial ability at the moment.
the rocker arms and top-side of the heads look pretty grimey. I noticed that the pcv fitting for the air cleaner assembly was missing from the valve cover....allowing dust and dirt and little crabs to find their way in there.
I have a couple buds coming over tonite to check things out.
So far we have:
-Loosen each arm til it clicks, tighten it til it doesnt click anymore, then add a 1/4 turn to that
-Liquid wrench for 15 minutes, then change oil
any other ideas?
Old Aug 21, 2003 | 12:16 AM
TBIfly's Avatar
not good....
it isnt the rocker arms being loose....
most likely piston slap or perhaps a wrist pin so im told.
I dont have the time to rebuild this 305 or even salvage what i can and put on a 350 tall-block. 80% chance I'm parting this car out now.
Old Aug 21, 2003 | 07:48 AM
Transmission: t-5
piston slap is more of a clunking sound. or aknocking,not a ticking noise. sounds like oil starvation still,try the liquid wrench
dimented24x7
Sep 6, 2015 03:51 PM
cstrobel65
Aug 15, 2015 10:19 AM
Dan87IROC-Z
Mar 1, 2001 05:27 PM
Black Missile
Oct 8, 2000 08:26 PM
Black Missile
Jul 31, 2000 02:24 PM
