Installing a "Pusher" Fan...
Old Aug 20, 2003 | 08:55 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
I need to upgrade my stock fan system on my '89 IROC. The plan is to get two Perma-Cool 16" fans, installing one on the radiator as a "puller" fan (like the stock fans), and then installing the other in front of the condenser as a "pusher" fan.
I know a 16" fan will fit on the radiator. The problem is, I'm not exactly sure that a 16" will fit on the condenser. Moreover, I'm not sure if the fan will run into any clearance problems being where it is.
Has anyone tried a fan setup like this before and, if so, could you offer some tips?
Old Aug 20, 2003 | 08:58 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
if a fan is pushing towards the front of the car how does that accomplish anything.....wouldnt it either be shielded from the wind and hence pushing warm air around in the engine bay or be open to the wind but then at any speed it would do nothing? Is it intended more for when the car is idleing??? i dont get it.
Old Aug 20, 2003 | 11:32 PM
sancho's Avatar
The idea behind the pusher is that it pushes cold air through the radiator. The stock fans, however, accomplish the movement by pulling air across the radiator. Both fans are moving air in the same direction through the radiator, they're just doing it from different sides.
Pushing cold
air through...
=====>==>=={||}==>==>===== ...and then pulling hot air out.
_____________^
(That's the radiator)
Old Aug 21, 2003 | 10:43 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Pushing cold
air through...
_____________^
i get it i thought you just flipped around one of the fans and i was like wtf???
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
