whats the difference between a 68-80 350 and 86 and up?
Old Nov 2, 2000 | 04:37 PM
1989CamaroRs's Avatar
a forged master kit for an 86 and up costs a good hundred bucks more
Old Nov 2, 2000 | 04:40 PM
GOLD85's Avatar
after 86 the blocks have a one peace rear main seal wich you need a speical crank for.
when the green flag drops the bull$hit stops
350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Old Nov 2, 2000 | 05:21 PM
does the alternator, ps, ac, and all that stuff bolt on the same?
Old Nov 2, 2000 | 06:38 PM
ScreaminDeamin85Z's Avatar
should
Old Nov 3, 2000 | 01:35 PM
md's Avatar
md
I'm assuming you have an '89 from your "handle".
You can not use a two piece seal crank with the post '86 one piece seal blocks without an adapter. The machine costs involved to make this conversion are spendy. The adapter is spendy too.
The post '86 engines are also an externally balanced engine requiring a matched flywheel/flexplate to the rotating assembly. Before everyone jumps in with disagreement of this statement, you need to know a few things first.
The post '86 engines with one piece seal use an entirely different crank. The work end of the crank has been machined to accept the one piece seal. This change eliminated the "flyweights" on the crank flange that the earlier cranks used to get the crank to “neutral” balance. GM fixed this by adding weight to the flywheel/flexplate to get the crank back to neutral balance. Therefor, the rotating assembly is no longer classified as “internally balanced” because weight had to be added to an attachment to the rotating assembly outside of the block. GM did this for monetary reasons because of the expense involved with using Mallory/heavy metal that would be needed to achieve a “neutral” balance of the crank.
Jake_92RS
Jan 28, 2020 10:37 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Eric-86sc
Aug 24, 2015 09:01 PM
neekolzun
Aug 24, 2015 04:59 PM
crazynights
Aug 21, 2015 06:53 AM
