dies at low idle
Old Aug 21, 2003 | 08:17 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
dies at low idle
i have to get this fixed before monday, the problem is that the engine runs fine at higher rpm like 2k, but around 1k it dies off and is hard to keep it to stay running.
its like the engine runs lean at low idle, also it burns oil, i just replaced the plugs and ignition system so i know its not that.
it just seems like it leans out at low idle, or the carb is just running lean, so can someone tell em how to make it run a tad richer, i dont have meetering rods and such and this is a non-computer controlled CC-quadrajet carb.
thanks in advance.
shean
Old Aug 22, 2003 | 02:42 AM
Squeeks83's Avatar
bump
Old Aug 22, 2003 | 07:55 AM
Vader's Avatar
Squeeks,
If you are running lean at idle, open up the idle mixture screws.
Old Aug 23, 2003 | 01:52 AM
Squeeks83's Avatar
i cant find the dam things on my carb, its a stock non-cc Q-jet, but i cant find the dam things.
jklein337
Sep 19, 2018 06:23 PM
Andrew6.688
Dec 13, 2015 10:59 AM
bamaboy0323
Sep 3, 2015 06:07 AM
perZ
Aug 21, 2015 05:51 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
