Non-Fbody, 71 Impala question..you gotta read this...
Old Nov 3, 2000 | 06:06 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I decided to replace the positive and negative cables on the 71. After I am done, I start the car, cool, no problem. I go to turn it off, it won't stop! So I hit my HEI anti-theft kill switch and the Temp and Alternator idiot lights stay lite on the dash! WTF???? I checked all the wires. I have one wire off the negative cable on the battery heading to the frame and one wire off the positive cable on the battery, heading to the voltage regulator. I am thinking something with the solenoid, but the only wire I found on the solenoid is the main battery cable. Am I missing something?
I really gotta ditch the voltage regulator and get a modern alternator.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Nov 3, 2000 | 07:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds to me like the wires on the starter are touching, such that the big red wire/battery cable terminal is touching the "R" terminal... since that terminal goes straight to the low side of the ignition switch, guess what...
Old Nov 3, 2000 | 08:39 PM
Rob P's Avatar
Engine: ZZ4TPI
Thanks for the advice, I am thinking that has to be it but I felt around and could find no other wires on the solenoid other then the main cable. I am gonna drop the starter tomorrow and see for sure. Thanks... amazing, try and fix one thing and cause a host of other problems!
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
92firebirdguy
Sep 1, 2016 07:53 AM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
Blue419
Sep 10, 2015 01:03 PM
IROCZ1989
Sep 4, 2015 11:54 AM
