Squeaky engine
Old Aug 23, 2003 | 10:19 PM
rjmcgee's Avatar
Squeaky engine
I have a squeak in the engine that is hard to track down. I think it is the pushrods rubbing on the guide plates, at least that is where I can hear it best with a stethiscope (sp). It sounds like a belt chirping at idle. I unhooked the belts which also stops the water pump and the noise didn't go away. I have Pro Action heads and Comp cam, pushrods, and rockers. I also can't see any wear on the pushrods or guideplates and everything is oiling fine on the top end. Any help would be appreciated.
Old Aug 24, 2003 | 09:17 AM
Vader's Avatar
Can you recreate the noise by turning the engine by hand? It might be an easier way to find it.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
