Head porting, should I radius the exhaust ports?
Old Aug 24, 2003 | 06:45 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
As the topic says, should I?
I'm thinking that I should radius them to match up with my headers (1-3/4) to aid in reversion.
What do you guys do?
Old Aug 24, 2003 | 08:10 PM
Vader's Avatar
Matching the flange openings is always worth a little bit more flow. Nothing phenomenal, but a little. As long as you have the grinder on that side of the head, make sure you smooth out the short side radii of the exhaust ports just above the valves. That's going to aid flow and reversion waves for scavenging even more.
Old Aug 25, 2003 | 08:14 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Thank You Sir.
Old Aug 25, 2003 | 12:05 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: Head porting, should I radius the exhaust ports?
If you mean to aid in anti-reversion, then the secret is to keep the exhaust port slightly smaller than the primary opening, preferably on the short side radii.
If you want reversion then making the ports the same size as the primaries is the right way.
Old Aug 25, 2003 | 12:35 PM
Vader's Avatar
Yeah, I was wondering that a little bit myself, but he did definitely say "reversion" after all. Hooker used to even have cones in their header flanges to induce wave reflection (reversion) at the head flange instead of the back of the valve, and hopefully adjusted their tube lengths accordingly. All-out setups always seem to calculate the runner volume and length right down to the back of the valve for best scavenging and tube tuning length. Then again, they're usually using megaphones or flared tips. That would be very difficult on a street engine, and probably not worth any more power after the shock waves fight their way through a converter and muffler.
Old Aug 25, 2003 | 01:02 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I guess I have my terminology messed up, I had thought that reversion aided in scavenging and by radiuing the port to the header flange would assist it.
That's what happens when I try to use big words
Old Aug 25, 2003 | 09:06 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Don't need to make the ex port opening huge.
It willl just make your headers more likely to leak.
But you can raise the roof of the port a little to good effect.
Working the bowl and guide area will help flow a lot more than the port exit. No need to get carried away.
LT1Formula
20
Nov 14, 2015 12:02 AM
beastin91rs
Oct 9, 2015 07:38 AM
hayesaw0210
Aug 23, 2015 11:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
mx127
Aug 10, 2015 08:13 AM
