jeez what is wrong with this car...
Old Aug 25, 2003 | 11:11 PM
83BlackBeauty's Avatar
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
ok i got the starter installed (finally) and when i went to hook the battery back up i had no power at all. Help!!!
Old Aug 26, 2003 | 04:59 AM
ede's Avatar
ede
charge the battery
Old Aug 26, 2003 | 06:44 AM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
I agree with Ede, first you should determine if your battery has a charge. If not charge it, or get a good one if its gone bad. If thats still not it, you need to look into your wiring theres a bad connection somewhere, or something was left unhooked. Check battery cables, make sure everythings securely put on your starter.
Old Aug 26, 2003 | 05:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Hmmm...
Had power before you changed the starter; doesn't have power after you changed the starter.
Sounds like you left some wires off.
There should be a couple of wires with a large ring terminal that go on the same post on the starter where the battery cable goes. Those connect the entire rest of the car to the battery. I'd take a look at those, make sure they're put back where they came from.
Old Aug 26, 2003 | 05:05 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
are u sure u put the wires on the correct small terminal? my starter had 2, one wasnt needed.
Old Aug 27, 2003 | 10:19 AM
ERICK87Z28's Avatar
Car: 1988 IROC
Engine: 5.7 HO TPI
Transmission: 4 spd Auto
Agreed, check and double check that you have all the wires going to the right terminals. They are very easy to get swapped around. Ask me how I know......
Old Aug 27, 2003 | 11:21 AM
Ryknow86's Avatar
Car: 84 Camaro Z28
Engine: carbed 350
when you say "no power" do you mean the starter isnt working, or no power throughout the whole car (lights, radio, etc.) if nothing throughout the whole car then its a dead batt, if not then check the wire connections.
Old Aug 27, 2003 | 11:59 AM
Car: 83 Trans Am
i figured it out it was a missing wire on the starter. thanks a ton
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
J.C. Denton
Sep 8, 2015 05:35 PM
