ATTEN: MASTER ENGINE BUILDERS AND BUFFS!
Old Nov 6, 2000 | 10:13 AM
92GTA's Avatar
I have several q's reguarding the engine I plan on putting in a 1991 GTA. Here's my plan:
1) Balanced 383 w/aluminum block plus forged pistons and rods.
2) 1000 cfm TPI intake, runners, and plenum.
3) ProCharger D Series w/3 core intercooler,
4) Custom burned chip,
5) MSD ignition,
6) Custom built 700R4 (I want overdrive for crusing),
My q's are:
1) What should my optimum compression ratio and boot pressure be??? I was thinking 8:1 w/15 lb boost??
2) What heads should I use??
3) What size cam and rockers, obviously rollers though...
4) What Injectors should I use??
5) Who can burn me the best chip??
6) What gears should I use, I don't want 4.11's, I was thinking 3.23's or 3.73's.....
6) + what am I forgetting????
About what should this put out with your answers?? I'm looking for atleast 12's if not 11's here and keep in mind this is in
a 91 GTA so it is heavy and I would be willing to use a 50-100 hp shot of nos to get there if I have too................I am dead
serious about this and I don't think I know that much about engines to please help me out and no put downs,
Thank You
www.TransAmGTA.com
1992 GTA(226 made), 1 of only 18 "Dk. Jade Met." 92 GTA's, Window Sticker, 305 TPI, 700R4 4-Speed, T-Tops, Grey Leather, every option except rear disk brakes (Oh well, makes it 1 of a kind), and CD.
Current Mods/Upgrades: 80 Series Dual Outlet Flowmaster, TPIS Air Foil, OE Replacement K&N Air Filter, and Mobil 1. THAT'S IT! 98% STOCK!
Future Mods/Upgrades: None but a complete restoration.
"If it ain't broke, fix it til it is!"
Webmaster www.TransAmGTA.com
My 3rdGen Firebird Message Board!
[This message has been edited by 92GTA (edited November 06, 2000).]
Old Nov 6, 2000 | 05:37 PM
md's Avatar
md
I'm assuming your aware that your describing a $15,000-$18,000 build. If your going to invest that kind of money, you may want to look at a big block build without the blower.
I have a 526 CID build coming up using a Donovan 10.200" deck aluminum BB. Dart Big Cheif CNC ported 18* heads and all the trick internal/externals. HP at 7500 is looking close to 850. It will run on 94 octane and still be somewhat streetable. Total cost for parts are about $16,000.
Food for thought....
Mike
Old Nov 6, 2000 | 07:03 PM
92GTA's Avatar
WOW!! I was thinking I could do it for maybe 8-10K........
Old Nov 6, 2000 | 07:31 PM
md's Avatar
md
The block will cost you around $5000 plus machine work. Heads are at least $1200, rotating assembly will be at least $1200, cam and valve train at least $1000,...... It adds up quick with this type of build and power levels. Then suspention work and drive train upgrades on top of that.
The 526 is going into '63 vette that's getting the frame stiffened, worked with cage, straight axle with a Strange 3rd member with coil overs, ...etc... The owner has about $5000 in that already. He has more money than he knows what to do with.
Might want to re-evaluate your wishes. Build yourself a stout 400/434 with an iron Bow-tie or Rocket block and ditch the blower. Save yourself about $6000. A 400 or 434 can be built to 600 streetable hp easily.
But then you still have to get it to hook up without breaking things.......
Mike
Old Nov 6, 2000 | 07:37 PM
MJT's Avatar
MJT
You can safely run 9:1 compression with a 3 core intercooler and 15 p.s.i. with the proper tuning.
Old Nov 6, 2000 | 07:59 PM
92GTA's Avatar
Thanks guys. How about since the block is so much, what if I just use an L98 block?? Or what could I expect to pay for a nice (used) seasoned aluminum block??
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
