fuel or sensor?
Old Aug 26, 2003 | 11:38 PM
sennap1's Avatar
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
fuel or sensor?
90 ws6 formula L03 TBI... new coil,dist,rotor,wires,INJECTORS,fuel filter., ok with everything said and done i get a fuel miss or a hesitation-if you will,under acceleration...and my engine light oh-so-briefly turns ON as soon as it turns OFF!..and GUYZ or GALZ-primarily when i turn a corner with gas applied!?????its not a constant thing,but it is definetely intermittent! AND NO SES CODES ARE PRESENT!
EGR?
TIMING?
FUEL PRESSURE CHECK?
VSS?
IGN.MODULE?
THANKS,ANTICIPATING SOLUTION!!!!-BRAD
Old Aug 27, 2003 | 08:01 AM
Vader's Avatar
No coes? Well, maybe. I'm just guessing, but you should at leat be seeing a '12' when you scan for error codes. The '12' actually means that teh ECM is not getting distributor reference pulses when the ignition is on. Normally, that is expected when scanning for codes, since the ignition is on but the engine is off. However, that can also mean that there was an interruption in distributor reference pulses when the engine was running. Sound familiar?
I'd check the distributor and EST wiring very closely. Umplug the connectors and inspect the terminals. Inspect the wiring for damage. See if the G forces of cornering can swing the wiring to a point of stress or possibly grounding. Check the distributor shaft for wear.
It sounds like something is killing your ignition pickup/reluctor pulses under loads.
Old Aug 27, 2003 | 10:27 AM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
My car used to do that...it was the pick-up coil.
Old Aug 27, 2003 | 12:03 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
I just made a post becuz my LB9 is doing the same thing! Got a new MSD coil on there yesterday, getting ready to put 8.5 MSD wires, but the ones on there now are new. Haven't done the cap and rotor yet, but have accel pieces to put on, plugs are in decent shape. Mine buts out like that under turning, as well as semi-hard braking. Does that sound like the EST or dist. to you guys? Its a TPI car so could there be something else?
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
bamaboy0323
Sep 3, 2015 06:07 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
