Clearance Problems with accessories and Pro Topline Cylinder Heads
Old Aug 27, 2003 | 07:30 PM
66_C10_TPI's Avatar
Does anyone know about interference problems between 180cc cast iron pro topline heads and the stock serpentine setup (92 camaro L98). Such as alternator, ac compressor, etc. I have heard that there are issues with bolt holes missing or not aligning with brackets and clearance problems between the alternator and valve covers. I would like to use these heads but do not want to have to get to get an aftermarket (March) setup.
Old Aug 28, 2003 | 06:58 PM
66_C10_TPI's Avatar
There isn't anyone using Pro Topline heads with the stock serpentine setup???
Old Aug 29, 2003 | 11:35 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I heard that on one of the accessory brackets you have to use only 4 bolts instead of five. Other than that I don't know. I have a Vbelt setup.
I know the pro heads have a thicker deck, so they stick up and out more. IE my hedman headers slid right in and out with stock heads, with the pros I had to jack the drivers side up a tad.
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
ZsTransAm
Aug 11, 2015 07:30 PM
anesthes
Aug 8, 2015 09:37 PM
