Car smoking....
Old Aug 29, 2003 | 10:50 AM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Car smoking....
Ok my car puffs out quite a bit of white smoke when I start it cold. I figure that my valve seals, but I have a problem with overheating when I sit in traffic for extended periods in hot weather, I can fix that by adding another fan, but it also smokes quite a bit when the temp gets to like 230 or so and up. Anyone know why its doing this? I'm really hoping its not a head gasket but I haven't ruled it out yet.....
Old Aug 29, 2003 | 12:38 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
it might could be a bad thermostat, fan switch, coolant temp sensor.
do you have enough fluids, the right mixture of fuilds.
see what someone else says
Old Aug 30, 2003 | 07:01 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Valve seats are usually what causes smoke on startup. Fuel mixture can also play a role. Mine does it a little, but it is fuel vapor from the engine being cold and no choke on my Holley. As far as your overheating that can cause the engine to have many problems with how it runs and how much oil leaks around the valves. Can also cause the idle speed to increase. If it gets too hot you can blow the head gaskets. The best way to cool your engine down is to get an aluminum radiator, make sure the thermastat is new. (make sure to drill two small bleed holes)(helps keep it purged of air bubbles and such). Make sure the electric fan sensor is working properly and make sure the antifreeze mixture is correct. The aluminum radiator will make a great difference, trust me. They dont cost much. Napa has them for $130 or 140. Can't remember. Modine Brand
Old Sep 9, 2003 | 10:15 AM
Engine: Mild 350
My fan switch isn't even a concern, have an aftermarket fan wired into fuse block,
Old Sep 9, 2003 | 10:53 AM
82camaro's Avatar
Car: 82 camaro SC
"but it also smokes quite a bit when the temp gets to like 230 or so and up." Are you saying when the engine is running it smokes quite a bit 230 and above, or is it still just when you start it 230 and above?
Old Sep 9, 2003 | 11:17 AM
Engine: Mild 350
With the engine running.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
