Need help choosing cam
Old Nov 8, 2000 | 02:02 PM
theformula's Avatar
First off, why is a rolling cam better than a regular one?
ZZ-9 Hydraulic Roller
Intake Exhaust
Advertised duration 282 287
Duration at .050 212 226
Gross lift .483 .520
Lobe separation 112
I want the ZZ9 cam , but I am not dishing out $375 for it. I'm pretty sure Crane Cams makes it anyway. I was looking through summitt and jegs today and came across about 5 different cams for my application. Please tell me which ones would work (and which ones would be the best) on my 92 5.0L TPI 5speed. My mods are listed below thanks.
Should I go with any of the following..which would be the best:
CRANE CAMS 270110592= 284/290* (adv. duration), 480/494 (gross lift)
CRANE POWER MAX 270109831= 284/292* (adv duration), and 509/528 (gross lift)
CRANE CAMS crn109831 = 222/230*(duration @.050), with 509/528 gross lift
CRANE CAMS crn109831 222/230 (@.050) with 509/528 gross lift
CRANE CAMS crn109841 234/242 (@.050) with 539/558
Can I use my stock rockers with a new cam ?
'92 Formula
305 TPI
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (50psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges...ZZ9 cam is coming!
[This message has been edited by theformula (edited November 08, 2000).]
Old Nov 8, 2000 | 03:58 PM
ede's Avatar
ede
for a 305 i'd stay in the .475 lift range and around 210* duration. a roller cam allows you to use steeper, or more aggresive, slopes on the cam lobes.
[This message has been edited by ede (edited November 08, 2000).]
Old Nov 8, 2000 | 04:19 PM
theformula's Avatar
Hey ede, do you mean 210 degrees at .050"?
'92 Formula
305 TPI
Old Nov 8, 2000 | 06:45 PM
mtx28's Avatar
w/ a 305 dont go over 210/215, you'll regret it.
Old Nov 8, 2000 | 06:53 PM
ede's Avatar
ede
yes @.050 any more most all cam grinders list the specs @.050 lift.
-=ICON MOTORSPORTS=-
1st & 3rd
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
