timing wire ..help me out here
Old Aug 30, 2003 | 09:07 PM
RICHRAD's Avatar
The tan wire with the black stripe I guess...Where is it located along the wiring harness....looked ,but did not see...where should I be looking exactly.. Like to be sure I get it unplugged before setting timing..oh yeah,, 86 lg4 t/a
Old Aug 30, 2003 | 10:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You don't have that.
You have a carbed car, so instead, you should be following those instructions, instead of the ones for FI cars.
Look at the distributor body; you will find 2 hanrnesses coming out of it. One has 3 wires and goes to the dist cap. The other has 4 wires and connects to a pigtail coming out of the big harness that goes along the back of the engine bolew the dist. You need to disconnect the 4-wire one. Do that, then crank the car up (it will run terrible and light the Check Engine light) and set the timing, then hook the plug back up and clear the light.
87350IROC's Avatar
Car: 87' IROC
Passenger side, firewall. Near the A/C box, if you have A/C.
Nevermind, RB already covered it.
Old Sep 2, 2003 | 04:00 PM
RICHRAD's Avatar
Hoping it wasn't that connector....tough to get to after putting on plug wires, vacuum hoses and oil sending unit.... and what if I have a cam break in to do, should I set the timing later AND JUST FIND A SPOT WERE IT RUNS SMOOTH UNTIL CAM IS BROKEN IN?
Old Sep 3, 2003 | 07:34 PM
87350IROC's Avatar
Car: 87' IROC
yes, breaking in your cam is more important
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
ZsTransAm
Aug 11, 2015 07:30 PM
apie2546
Aug 8, 2015 07:12 AM
