ECM and T56question
Old Nov 9, 2000 | 07:29 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
ECM and T56question
I may be swaping to a t56 and want to know 2 things.
1. do i need a different drive shaft than the 700r4 one?
and
2. will i have to have my prom redone with the swap to a T56.....boy I hope not but if so looks like ill learn to burn..
well 3. think a t56 will hold upto 536RWHP 569FT LBS? if not may not even be worth the swap.
Chris
1992 25th Anniv Z28 W/383 Stroker
536 RWHP 569 FT LBS
(chassis dynoed at Ramsies Perf.)
www.go.to/TPI383
Old Nov 9, 2000 | 03:14 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
COme on somebody must know...
Old Nov 9, 2000 | 06:34 PM
mtx28's Avatar
i dont think so, look in the FAQ section on the main page, i think they say drive shafts the same length. i run carb, so dont know the other part
Old Nov 9, 2000 | 07:03 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
You can keep the stock length driveshaft and torque arm as long as you get a T56 out of an F-body.
The AFTERMARKET BW T56 kit requires you to shorten the driveshaft and torque arm.
Don't know about the prom thing...
At those power levels, I see a lot of guys switching to a TH 400. That's not to say a T56 can't handle that much power...Viper's seem to do it fine. It's just if you drag race a lot a beefed up auto will be better in your application.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Nov 9, 2000 | 09:22 PM
IROCracer's Avatar
Why didn't anyone email me on this??? Boy, I'm glad I stopped in. OK, get a T56 from an Fbody, use your stock driveshaft, but GET THE TORQUE ARM MOUNT THAT GOES ON THE T56!!!!! You can use your stock prom, anyone who says otherwise is full of horse****. If you have 2.77 gears, might wanna switch them, but I'm running a stock TPI 350 (well, pretty much stock anyways), and I have 2.77 rear gears, and the 2.66 first gear ratio, and this damn thing still WAXED a 93 5.0. Get it done, it'll hold the power, and it's worth it.
Kelly
If you've gotta fix it, fix it better than stock.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
