Is my alternator going out?
Old Sep 4, 2003 | 02:29 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Hey Guys
I went to take my girlfriend home last night....and earlier during the night, I noticed my dash lights and interior lights getting dim...I looked at my battery guage and it looked ok...well..later during the night, while I took my girlfriend home, the lights almost went completely out...then my engine quit....everything quit and the battery guage was in the red zone. I had to coast to a stop and walk about a 1/2 mile to a gas station. My brother jumped my Camaro but we had to jump it 3 times to make it home because it kept loosing power. I put it on the battery charging and started it, let it run for about 1 minute...and there we go again....the guage dropped and my car shut off and everything is dead. That battery is only about 8 month old. So...I thought maybe the alternator might be going bad. Any thoughts?? I just know I need to fix this problem....
Old Sep 4, 2003 | 02:36 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Sound like you have a bad alternator bud. There are two ways to tell for sure, the first is take it off and take it to your local parts store, they should be able to test it. You can also charge the battery and start the car, then test the voltage on your battery with the car running. Voltage I believe should be 13-14 volts. If its low, your alternator is shot. But personally I say its gone man.
BTW, thats a sweet Z you got there!!!!
Old Sep 4, 2003 | 05:10 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
yep, bad alternator
Old Sep 5, 2003 | 02:22 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
change your belt too, a slipping belt will keep the alternator from cranking out enough amps
(edit)
nevermind, its a 91, it thought it was an 84 with v-belts
Old Sep 5, 2003 | 04:47 PM
Engine: 5.7
it was the alternator for sure, I had the original tested at autozone and it was only throwing out 2 volts....bought a new it and it works fine. Thanks for the help fella's!
Old Sep 8, 2003 | 11:42 AM
Wallace's Avatar
I'm glad you got it fixed, that is one awesome looking Camaro.:hail: :yourock:
Old Sep 8, 2003 | 12:48 PM
Engine: 5.7
Thanks alot man, I appreciate it.....not to many people arund here say much to me about my car....they just wanna know how fast it goes...haha. I'm going to be havng about $50,000-$100,000 coming to me.....sooo....I'm just getting started... .
I was in an accident with my old 84 Z28, an 83 year old lady hit me and I'm not disabled 5%.....soo...I'm getting some money out of that...
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
