Max cam lift for a 305?
Old Nov 12, 2000 | 01:00 AM
Smasher's Avatar
Ok, whats the maximum amount of lift I can run for a barely streetable 305?
I want to run the Comp Cam XE262H grind as recommended by ws6transam, but is it possible for me to step up one more size to the XE268H grind?
Specs for both are as follows:
Comp Cam XE262H- 218/224@.050 .462/.469" lift
Comp Cam XE268H- 222/230@.050 .477/.480" lift
Ryan- 1985 Monte Carlo CL
Yes, I'm bitter towards the SS
Tealnet Your #1 Automotive Resource on the 'Net
http://scaryfast.homestead.com/ <--- My homepage
Old Nov 12, 2000 | 07:33 AM
ede's Avatar
ede
can't remember exactily but the last time i check piston to valve clearance i think it took right at .7 to hit a piston with a valve at tdc. i'd say aything under.6 lift would be safe, but it's always a good idea to check
-=ICON MOTORSPORTS=-
1st & 3rd
Jake_92RS
Jan 28, 2020 10:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
anesthes
Aug 8, 2015 09:37 PM
