Timing advance questions
Old Sep 5, 2003 | 12:10 PM
martyr's Avatar
Car: 88 Formula 350
Engine: 357
Transmission: 700r4 Edge 2900 Stall
I kno wthis is going to sound stupid..but so be it
Where/ how do I advance the timing; by physically turning the distributor or by changing settings in the prom?
What are some good initial settings given the mods in my signature line.
Thanks!
Marty
:lala:
Old Sep 5, 2003 | 01:35 PM
Morley's Avatar
Leave the timing at the factory 6* BTDC, unless you are going to burn a chip with a different base timing.
To set the timing you disconnect the EST wire, located along the firewall, above the heater box (towards the middle of the car), it is a brown wire with a single connector. After disconnecting that you start the car, set the parking brake, block the wheels, when it enters closed loop, put it in drive, check the timing. If it needs adjusting you loosen the distributor clamp bolt and while pointing the timing light at the tab/ balancer, turn the dist until the timing is at 6* BTDC. Tighten the dist clamp bolt, recheck the timing and if it is still at 6*, turn the car off, reconnect the EST wire, disconnect the neg terminal from the battery (clears the est code that was set when the wire was disconnected), reconnect the battery and start the car, make sure no check engine light comes on when running/driving.
Old Sep 5, 2003 | 02:30 PM
martyr's Avatar
Car: 88 Formula 350
Engine: 357
Thanks for your reply.
I can reprogram the chip if necessary to increase performance. Is there a definate SOP difference in advancing the timing a little.
If I can make a few subtle changes to the prom then that would be great.
Old Sep 5, 2003 | 04:25 PM
Morley's Avatar
That is dependant on the engine, some will react well to 2-3* more advance and others (mine) react poorly. You may feel a difference in launch but as the RPM's rise and more timing is added via the programming you may run into detonation, which will pull timing and cause a power loss.
Old Sep 5, 2003 | 04:55 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
just as a thought advancing the timing a bit is one of the features of the hyperjunk chips.
Old Sep 6, 2003 | 08:40 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
How do you check timing electronically?
My tab is off but I don't remember which way and I have suspicions about my balancer.
I thought my scanning software would show me the desired 6 deg with the EST disconnected but it was showing me 20.
Old Sep 6, 2003 | 08:53 AM
Morley's Avatar
You don't, though I suppose you could disconnect the EST wire and see what the scanner says your timing is at when at idle.
Old Sep 7, 2003 | 09:06 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I tried that and the scanner said 20 while my timing light said 6.
pfsteichen
Feb 9, 2016 06:59 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
