MSD Coil installation
Old Nov 9, 2000 | 06:21 PM
Monkie's Avatar
Ok I got my Blaster 2 coil today from Summit. The installation paper has 5 setups. I dont know which one I am supose to use. Do I use the power tower? Or do I use the "GM Dual Connector Coil"? Thanks!
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
8.5mm MSD Ignition wires
Old Nov 9, 2000 | 11:45 PM
MikeC.86Roc's Avatar
The only thing I can say to help is that I used the Tower power on my HEI ignition on my truck (with integrated cap and coil). Then I remote mounted the coil to the firewall. The instruction booklet included in the kit should guide you through the different types of ignition systems that are close to yours...
Old Nov 10, 2000 | 01:34 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I would say you have to go with the two connector coil directions if it's the direct fit coil.
Old Nov 10, 2000 | 01:33 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Follow the directions for dual connector coil, becuase that's what you have.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 11, 2000 | 11:01 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I'm with tom and paul. Dual connector
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-Future:
-383 Stroker?
Old Nov 11, 2000 | 06:21 PM
Monkie's Avatar
Yea Ive figured it all out. But I just found out that I only have 7mm wires when I thought my car came with 8mm. So Im gonna get the MSD 8.5mm wires. Good idea?
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
Old Nov 11, 2000 | 09:03 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Monkie - I have a sort of "used" set of 8.5's if your interested in saving a few bucks. What happened was that I bought a new set (for V-8) and burnt a wire. I just put a new set on when that happened. The set with the burnt wire had less than 2000 miles on them, 90* boots. I'll entertain an offer for them, but be reasonable...
KAM
Old Nov 12, 2000 | 12:59 PM
Monkie's Avatar
KAM
I would think about it...But I just ordered the MSD wires last night from summit. Thanks anyways!
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
9192camaro
16
Feb 3, 2019 12:21 AM
toronto formula
Nov 10, 2015 06:17 AM
TheExaminer
Aug 25, 2015 07:34 PM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
