estimate HP here, not sure
Old Sep 5, 2003 | 08:08 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
ok, heres what i know for sure about the engine,
350 4 bolt
.30 over
cam 537/554
holley double pumper
holley (looks like the weiand tunnel ram intake man)
dome pistons (biggest you can get)
13.something:1 compression
3500 stall
th350 man valve body all billet aluminum
all foraged parts
solidlifter, roller rockers, double valve springs
msd 6a ignition
worked heads
my buddy was guessing 650 hp, but i am going with more, but i want to know you guys opinion, cause i am going to be getting the engine an trans combo, and i wanted to know what will be too much, he is giving it to me cheap cause i have known him for 10 years, but i want to know if it is worth it(probably going to sell it to me for 3400 he said), and what you think it might produce hp wise, and what a est ET will be with slicks on the back, thanks
Old Sep 5, 2003 | 08:14 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
400hp looks like a mismatch of parts if you ask me.
Old Sep 5, 2003 | 08:46 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
not 650 but we definitely need other specs like the heads and what holley duble pumper you have.
Old Sep 6, 2003 | 01:19 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What size carb(s)?
What is the rod length (won't affect hp really, but helps other things)?
What are the rest of the cam specs?
What heads?
What was done to the heads?
What headers / exhaust system?
What kind of induction (cold air intake, ram air, cowl, etc etc)?
What is the rocker ratio?
What (if any) oil scraper / windage tray?
What fuel are you using (gasoline, alky, etc)
What octane (if gasoline)?
Something like that is gonna have ALOT of top end and a pretty soggy low end, especially with a tunnel ram intake... i would maybe go with a high stall speed.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
skip91
Sep 24, 2015 03:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
bellez77
Sep 5, 2015 08:39 PM
Trevor K
Jul 12, 2001 01:44 PM
