Dipstick Holder & Headers, DO NOT FIT
Old Nov 12, 2000 | 04:26 PM
nesluopetan's Avatar
I just put on some edelbrock TES headers on my 82 Z28 camaro, and now my dip stick holder wouldnt fit, i tried to bend it and it snapped, I need a new one, and was wondering if they make them especially for headers, please let me know asap!!! thanks so much, with a link to the companies page, etc..
Old Nov 12, 2000 | 05:01 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
your suppose to rip that piece off and use the supplied dipstick holder in the kit.
Old Nov 12, 2000 | 07:31 PM
DSouthern's Avatar
I also had to work on the dip stick tube for quite a while to get it to work.
What I did was cut off the stock dip stick holder bracket which bolted to the stock exhaust manifold.
Then I turned the dip stick tube forward and used the supplied bracket and bolted it to the number 2 exhaust tube. I believe I had to bend the tube a little to get it to work but don't over do it.
Also, be sure to use some RTV sealer on the tube before you put it in the hole in the block.
Basically, my oil dip stick handle faces to the front of the engine now, instead of staight up, but is easy enough to remove and replace when checking the engine oil.
If you broke the stock dip stick tube I would get a replacement so you can reuse your stock dip stick.
Hope this helps.
Old Nov 12, 2000 | 07:33 PM
Tom Keliher's Avatar
Well, if you read the direction sheet, if it is the same as my TES headers, it tells you that the dipstick tube and header must be lowered and drawn into place together with each other. If you bolt the header on first, you won't get the dipstick tube inserted properly. Once it's all in place, the two clamps provided in the header kit are used to secure the dipstick to the header tube.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Dyno Don
17
Nov 2, 2015 11:43 PM
mustangman65_79
Aug 13, 2015 07:36 AM
matthew911
Aug 12, 2015 09:38 AM
Leggman1
Aug 6, 2015 04:15 AM
