knock question poss simple
Old Sep 6, 2003 | 02:43 PM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
what will happen to timing if the knock sensor grounds out on header per formed search already aswers very vague.
thanks in advance
87 pontiac gta tpi 350
Old Sep 7, 2003 | 01:18 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
If your knock sensor grounds out, the cpu wont receive the signal from it and it will not advance your timing. You will have base timing.
Old Sep 8, 2003 | 09:20 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
ok. thank you
now if i disconnect the est where should my timing be for some reason it is showing up towards the drivers side of the crank pully. far enough over that it won't read on the timing tab it shows up to the drivers side of it.
is it possible that the distibuter could be 1 tooth off?
i though the distributer could only be off by 180deg due to the blade that sits inside the bottem of the distributer gear on the distributer?.
Old Sep 8, 2003 | 09:21 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
keep in my this is a tpi 350 with mass air flow meter 1987
Old Sep 8, 2003 | 11:23 AM
dankhound's Avatar
Car: 91 RS
The blade on the bottom of the distributor shaft just drives the oil pump. Sometimes you have to turn it to get the distributor in right. The timing mark to the drivers side of the crank indicates a slight retardation of the timing but with the est wire disconnected it cant be the knock sensor. Hows your car running? If it was off a tooth it wouldnt run very good and if it was off 180 youll get a lot of backfires when you try to start it. You might want to try turning your dist cap to try and advance your timing a little.
Old Sep 8, 2003 | 12:48 PM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
car seems to run fine until cl;osed loop operation.
at which point the idle drops and the car will die unlesss foot slightly on gas. runs as though theres a cam. then dies
no there are no vacume leaks. checked checked and rechecked
i'm now lost don't know what it could be repaired knock sensor circuit still runs the same timing not moving still reading to tye drivers side of timing tab. i will try to turncap but it locks in place with 2 screws would have to twist dist.
also car gets alot of pinging when at wot. and shifting gears.
i would think that i need to turn timing down not up. correct me if i'm wrong
Old Sep 17, 2003 | 02:30 PM
lykan's Avatar
The cap does not turn, the WHOLE distributor does.
Under the distributor there is a bolt that holds down the distributor, loosen this, and the distributor should turn freely, and you can adjust your timing. I recomend only turning the dist when the car is running, preventing you from turning it too far and not allowing your car to start.
My 350 does the same thing with the timing, either the knock sensor is bad, or im picking up false knock.
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
