switched tbi to carb.... pump pressure problems
Old Sep 6, 2003 | 07:40 PM
nathan2003's Avatar
Car: Camaro
ok i just switched my tbi to an edel 600cfm carb and i am having problems... k.. i have an electronic in the tank fuel pump that is puttin out 43 psi.... and i can not get a regulator that will drop the psi down anywhere even close to 5.5 - 6.5 and i don't really wanna rip out the tank or any of that stuff. i do have a bolt on for mechanical pump but i will still hafta drop tank to get it to work properly due to the pump in the tanks saftey shut off... right ?? so do i have anyother options i can do to avoid having to drop the tank ???
Old Sep 6, 2003 | 08:09 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
I had the same problem when I swapped my S-10 from 4.3L to a carbed V8. This is all I needed to make it work,
Summit #HLY-12-501 $47
Attached Thumbnails switched tbi to carb.... pump pressure problems-hly-12-501.jpg
Old Sep 6, 2003 | 09:29 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
the holley one cannot handle 43psi of incoming pressure. not deigned to. can handle 15psi. the one to get is the maa4309 from summit. it'can handle 50 psi incoming and has a return port on the bottom to plumb back into the return line on the car. but i have a question how is it that you have a intank pump putting out 43psi on a TBI car? the factory TBI pumps are rated at 20 psi.
http://store.summitracing.com/partde...art=MAA%2D4309
Old Sep 6, 2003 | 11:10 PM
nathan2003's Avatar
Car: Camaro
well sory that was my bad for blabbin out some thing when i didn't know for srue... i was just told that , that was what mine was supposevly puttin out so i didn't know what to think... i figured that was correct sorry about that... thx for the link to the pump... its greatly appreciated....
Old Sep 6, 2003 | 11:11 PM
mrr23's Avatar
Engine: 360 HSR
no problem. thought maybe you put a TPI pump in or something was really wrong like a pinched fuel line.
Old Sep 7, 2003 | 01:51 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
mrr23 is right on the other style makes a dead head in the line and will shorten the pumps life. the return reg. is the way to go.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
jklein337
Sep 19, 2018 06:23 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
