How do you pull a rear axle on an 84z
Old Sep 7, 2003 | 01:21 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
My driver side axle I believe is stripped, and I need to change it. I have pulled the center cover, but I was just wondering which bolts I have to take out just to pull the axle out. I am running a power traxx locker, will I have to remove that. Any help is appreciated. THanks in advance Jason
Old Sep 7, 2003 | 03:53 PM
ede's Avatar
ede
remove the cross bolt then remove the pin it goes through, push axle inward and remove c clip, if it doesn't fall off, them pull axle outward. your manual ought to have pretty good pics and locations of the parts. when you have the pin out make sure it's in park or gear and don't move or other wise spin the axles or carrier. the carrier doesn't have to be removed.
customblackbird
Aug 15, 2021 10:16 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
E Rod
Aug 28, 2015 05:17 AM
madsv1000
Aug 20, 2015 06:45 AM
