Oil leak by the starter..main seal right?
Old Nov 13, 2000 | 11:38 AM
Yarnboy's Avatar
I leak about a quart and a half of oil a month and it's ALL going on to the tubing that leads to the cat. I've always thought it was the main seal..but I looked closely..it looks like it's coming from where the starter attaches to the bellhousing..is that right? I could be imagineing things..is there any other place it could be leaking from? Thanks..
Also, does anyone know if Camaro Performer is a real magazine? I have only seen one..that's the one with the grey thirdgen on the front..I want to subscribe but I can never find any info on it and the super chevy website ignores the fact that they printed that magazine.
-Red '88 IROC 5 Speed 305 TPI w/3.08
-Dual Friction Centerforce Clutch
-Accel 300+ Racing Ignition
-Accel 300+ Pro Sleeve Plug Wires
-Accel U-Grove Plugs
-Flowmaster Force II 3 Chamber Cat Back Exhaust
-Hypertech Chip
-Hypertech Airfoil
-Removed, Then Re-installed (out of fear) MAF Screens
-Gutted Air Box
-Best E/T 14.90, 60 ft. 2.17, 1/8th mile 9.61(bald tires, Code's 34,36)
-Best MPH 92.7(bald tires)
Old Nov 13, 2000 | 12:46 PM
Bort62's Avatar
Look at the rear oil seal that goes around the crank. If this is bad, Oil will leak out onto the flywheel, and get thrown on that side of the Dustcover, that could cause It to Leak out near the starter.
Try this.
Take the dustcover Off, and Rev the motor In park. If the crank seal is leaking, You will soon see little speks of oil all over the driveway.
You can also peer up there with a flashlight and see pretty well where its coming from, but be really careful of that flywheel
85 Z28 - Daily Driver
60 Ranchero - Project ( Money Hole )
Old Nov 13, 2000 | 01:14 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
The Camaro Performers magazine was a one-time thing. I don't know if they issue it every now and then, but it's not a regular magazine - once a month. I've been subscribed to Super Chevy for quite some time now, and it was the first one I ever saw.
KAM
Old Nov 13, 2000 | 01:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Much more likely to be a valve cover or intake manifold leak than rear main seal.
Old Nov 13, 2000 | 02:06 PM
mtx28's Avatar
i think camaro performer is like 3 or 4 times a year, i have the one you are talking about and one other
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Gunsbee
Sep 7, 2015 07:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
