does anyone have the tpis zz-9 cam?help!!!
Old Sep 8, 2003 | 06:58 PM
stuart's Avatar
Car: 88 gta ....89 formula 350
Engine: 5.7......383
Transmission: heavily reworked 700r4
is anyone running the tpis zz-9 cam?......my motor right now is a 350 c.i. tpi. its bored 30 over, roller rockers/ lifters, headers,ported&polished vortec 64 cc heads, ported plenum, sdpc vortec intake, 24# injectors, edelbrock runners, 10-1 compression, im looking for a hyd roller for this new setup. does anyone know the kind of horsepower/torque #s this setup will produce, and is there a better cam that i can use for this application?...i want it to make everything it can at or below 5500 rpm. thanks
Old Sep 8, 2003 | 07:47 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Until recently I was using the ZZ9, good cam. I had buckets of power down low and to about 5000. I never made it to the dyno though before I got the blower bug...
I can say I really upset my friend and his 99 Slowbra(Cobra!). He was running mid-high 12s. I also never made it to the track.
I had a 383, AFR 190s, 11:1, and much more I don't feel like typing now...
You could also look into the LPE 219 cam. Many a TGOer are using that cam with great results...
Old Sep 9, 2003 | 12:28 AM
stuart's Avatar
do you have the specs on the lpe cam?
Old Sep 9, 2003 | 02:54 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Check out www.lingenfelter.com
The "219" cam I am refering to specs as follows duration 219* @.050 with .560" lift with 1.6 rocker arm ratio...PN 74219
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
