Car Vocab
Old Sep 6, 2003 | 10:03 AM
D M N's Avatar
Car: Right now 93 Lumina
Engine: 3.4 DOHC
Transmission: 4T60-E
Car Vocab
ok i have been hearing something on this site that i dont know quite what it means and i was wondering what some of this stuff means i have done surches but sometimes its doesnt clearly state the answer or i dont have the right spelling ok anyways
What are some terms that are important to know when getting a engine machined? (Ignorant people are usally taken advantage of)
When a head has 76cc what does that mean?
What does it mean when your fuel is Lean?
What does it mean when your fuel is rich?
What is octane? and what does it do?
I will think of more when they come to me
Old Sep 6, 2003 | 10:13 AM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
ill try to answer as many of your questions as i can:
1. cylinder head combustion chamber size, basically the "bowl" that the valves are in, that causes the combustion chamber (sealed area that piston is in when the head is on the block) to be a certain size. a 64cc head will give ya more compression than a 72cc head. smaller area, more pressure, understand?
2. too much air, not enough fuel
3. vice versa
4. kinda know what this means, not sure enough to try and make an educated guess, so i guess we'll both learn from this 'un, huh?
hope this helps!
Josh
Old Sep 6, 2003 | 10:57 AM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
octane...the basics, 87 octane burns faster than 89, 93, 110 ect, the higher the octane the slower and cleaner it burns. thats why if your car detonates or "pings" you put in a higher octane, the flame is exploding rather than burning and pushing down the piston.
Old Sep 6, 2003 | 11:48 AM
Vader's Avatar
For a good guide to general systems information, this link is decent:
http://www.acdelco.com/html/as_guide_main.htm
For a little more technical information on engines and building, this site is pretty good:
http://www.grapeaperacing.com/GrapeA...tech/index.cfm
Old Sep 6, 2003 | 11:59 AM
D M N's Avatar
Engine: 3.4 DOHC
in what situation would you need higher octane?
Old Sep 6, 2003 | 01:45 PM
MasterEvilAce's Avatar
higher compression engines require higher octane
slight example:
let's say that you have 10:1 compression (the air and fuel gets compressed in the cylinder to a 10th the original size.. i believe)
this is high compression, and for the example, let's say you put 87 octane in the car, the car will probably studder HORRIBLY
this is because the gas is igniting and going off before the piston is at the top of the compression stroke, thus, the pistons are being forced in the opposite direction too quickly, and the car doesn't like that
so, you'd have to use a higher octane (prevents the fuel from igniting prematurely) and your car will run smoother
vise-versa is the same. high octane in a low-compression car will screw up the car, too. The gas WON'T detonate when it's required, or something
Diesel is essentially very high octane, I believe. Diesel engines don't have spark plugs, they compress the gas so much that the gas ignites, creating the detonation, or explosion, whatever you wanna call it. Diesel engines have in upwards of 20:1 compression, i think.
Old Sep 6, 2003 | 04:03 PM
D M N's Avatar
Engine: 3.4 DOHC
are there any formulas to figure out how much octane you need??
Old Sep 6, 2003 | 09:09 PM
sure, you can do it in a Formula. An IROC-Z or a Z28 and even the Trans Am seem to work well too. lol, j/k. no, there isn't really a formula that i have heard of, the "pros" who have built a couple engines just seem to know what to use. you just start with say, 87, and if she pings, move up...
Josh
Old Sep 7, 2003 | 01:05 AM
Engine: hamsters
Josh
yep, ping means higher...
Old Sep 7, 2003 | 03:13 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Octane is (in a way) a measure of how resilient a fuel is to combustion. The lower the octane (ex. 87) the easier it is for the engine to ignite, but also, the easier it is for it to burn itself (detonation, pinging). The higher the octane (ex. 104) the more resistant it is to combustion, making it harder for the engine to ignite properly. This is why it isn't a good idea to use the highest octane pump gas you can get in a low compression engine. The up side to this is that it is more resilient to self-destruction (detonation) in a very high compression engine.
Basically, to have the engine run its best and make the most power, you want to use the lowest octane fuel your engine can handle without pinging.
As far as pump gas goes, I wouldn't reccomend any higher than 10:1 with cast iron heads unless you and engine tuning whiz.
Old Sep 7, 2003 | 08:26 AM
D M N's Avatar
Engine: 3.4 DOHC
Re: Car Vocab
ok i know enough information about octane someone help me with this
For example when i want to get my car checked for cracks and see if its still good do i just say that or is there a word for it?
Old Sep 7, 2003 | 11:23 AM
Morley's Avatar
Re: Re: Car Vocab
You mean the engine? You have the heads magnafluxed (special machne for checking for cracks) and get the block checked...they might use dye penetrant or eddy current to check it.
Old Sep 7, 2003 | 01:39 PM
Air_Adam's Avatar
At the machine shop, you probably want to have the block bored and honed, the mains line-honed and the block (and maybe other parts too) magnafluxed, which is a method for checking for cracks.
Old Sep 8, 2003 | 03:31 PM
D M N's Avatar
Engine: 3.4 DOHC
whats it called when they straighten up the part of the block so that the gaskets fit better
I remember hearing this along time ago
Old Sep 8, 2003 | 05:29 PM
Air_Adam's Avatar
You mean the head gaskets?
Thats called "decking the block".
Old Sep 9, 2003 | 03:22 PM
D M N's Avatar
Engine: 3.4 DOHC
yea thansk
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
