Spark Plugs very black and crusty
Old Nov 13, 2000 | 02:21 PM
Steve89GTA's Avatar
Hi all, I changed my spark plugs this weekend and noticed that they are very black and a crust like substance has mated to them. I get a dark...soot-like residue coming from my tail-pipes. How can I make my car run less rich!!!!
89 GTA
305 TPI
WC 5spd w/3.45 rear
Accel Cap & 8mm Taylor's
MSD6A Ignition
Accel Supercoil
Custom Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch
Hypertech Thermomaster Chip
Steel Rad
Cat back 3" Exhaust
HiGh FlOw Dynomax Cat
Old Nov 13, 2000 | 02:36 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Back off the fuel pressure. But the thick crud may also be due to incomplete combustion due to poor plugs/wires/cap/rotor.
Old Nov 13, 2000 | 02:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Maybe check the O2 sensor too? I'm surprised that you wouldn't be getting a code if it was running that rich.
1984 Silver Z28, 383 cid 4 bolt, ARP Fasteners, 2 1/2" Cowl Induction Hood, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Magnum Roller Tip Rockers, MSD6AL Ignition, Blaster2 Coil, Recurved HEI Distributor, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flo-Pro Twister Muffler, 4 Wheel Disc Brakes, Oil Cooler
Old Nov 13, 2000 | 07:23 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
My car (91' bird LO3) seems to be running very rich too. It blows soom kind of liquid/solid? (haven't really figured it out) out of the tailpipe and it stains rocks and cement. I just changed the rotor because it was very, very bad. I'm gonna try plugs and cap next. The wires seem to be fine but if they turn out bad what should I replace them with? My car is at a shop right now. If the mechanic gives me any solution or leads I'll post them here. Good luck.
Old Nov 14, 2000 | 09:36 AM
Steve89GTA's Avatar
Accell cap and rotor 25000km's old
Taylor 8mm wires 25000km's old
sparkplugs are of the same age
car boggles a bit while accelerating slowly in neutral from idle to 2000..feels very strong though...
Maybe I should pull the cap off and see what's going on under there...
89 GTA
305 TPI
WC 5spd w/3.45 rear
MSD6A Ignition
Accel Supercoil
Jet Airfoil
K&N Airfilter
Steel Rad
Cat back 3" Exhaust
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
