homemade AFPR
Old Nov 14, 2000 | 11:17 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
homemade AFPR
i've heard people putting quarters in their FPR off of a TPI to make it adjustable...can anyone give me info? thanks!
89 GTA
Rice....it's whats for dinner
The left lane is for passing...if you aren't passing get the f*ck out of my way!
Proud memeber of the South Jersey Fbody Crew(all 2 of us!)
http://www.hometown.aol.com/clarkemustgonow
Tony
Old Nov 14, 2000 | 01:06 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It doesn't make it adjustable. It simply makes the fuel pressure rise by a specific amount. You need a way to move that quarter up and down for it to be adjustable, but the top cap doesn't have the strength to support a threaded screw.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 14, 2000 | 01:26 PM
fly89gta's Avatar
Car: 2018 Camaro SS
thanks jim.....now i have another question for u....can i relocate the pressure regulator...cause i don't feel like pulling the plenum everytime i wanna mess with it...are there any tech files i can read of this procedure? i dont feel like spending $60 on a new one when can rip mine for $.25 or $.50...all depends on the amount of quarters i need any more info would be great!! thanks
[This message has been edited by fly89gta (edited November 14, 2000).]
Old Nov 14, 2000 | 05:48 PM
89GTA5spd's Avatar
You can make your own by jb-welding (or actually welding) a nut to the top of your stock fpr and then putting a shim and a bolt through the nut you welded. someone wrote a article about making one i think. It takes maybe 30 minutes to do it right. I did it, and now I have an extra holley afpr sitting around.
It would cost a lot of money to re-locate your fpr and probably wouldn't be possible to do without custom machining.
Just make your own and buy a fuel pressure guage... then your set.
Old Nov 14, 2000 | 08:51 PM
Vader's Avatar
Fly,
Jim is somewhat correct. The old "quarter-in-the-cap" trick doesn't make it adjustable, but this modification does:
AFPR.pdf
You'll need Adobe Acrobat Reader to view/print the file (see link below).
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
