What type of crank pulley?
Old Sep 12, 2003 | 06:24 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I'm only running an alt. pulley and a crank pulley. The alt. brackets that I have, possition the alt. pulley closer to the balancer/motor. Is there a stock serpentine pulley that I can buy that will work?
Old Sep 12, 2003 | 09:33 PM
Vader's Avatar
No water pump drive?
Measure teh length of the required belt with a string. Take the measurement to your local industrial power transmission supplier. They'll have whatever length you need. Poly V belts are manufactured in various cross sections in about 20mm increments. Gates, Dodge, Goodyear, and Browning should have a standard size that is close enough.
Old Sep 13, 2003 | 01:00 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
I see how confusing my initial post was. Sorry about that. I'm not worried about a belt. I need to either space the alt out from the motor almost 2" or move the crank pulley back 2". Which would require me to buy a different crank pully.
The pulleys are not lining up.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MM2Robinson
Oct 1, 2017 09:16 AM
djmarch
May 8, 2016 11:32 AM
BDR
Nov 7, 2015 03:05 PM
Hello, Michael
Sep 11, 2015 01:10 PM
