how to measure for pushrod length?
Old Sep 13, 2003 | 07:16 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
how do I measure for pushrod length?
I know to get a pushrod length checker, but what is the procedure?
Old Sep 14, 2003 | 12:26 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
With the valve, spring & retainer installed,
use one pushrod of known length...preferably on the short side of stock length.
Get the cam over to the base circle.
One way is to crank the engine over by hand until the #1 exhaust valve just starts to open (with a rocker-arm installed),
then you would use the pushrod checker on the intake side of #1 cylinder.
Another way is to turn the crank to the (Compression) TDC mark and use the pushrod checker on the #1 intake side.
Stick the checker on the stud and then use a feeler gauge to test the length between the checker and the short pushrod.
Get a rod with the new longer length (old + feeler gauge reading) and install a roller rocker @ zero clearance and with a thin dab of antiseize on the roller tip that contacts the valve-tip.
Turn the engine over by hand so as to go through one rocker arm lift cycle so you can check the contact area on the valve-tip as left by the antiseize.
Old Sep 14, 2003 | 01:29 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
get the comp pushrod checker they come in a variety of sizes
I have a couple
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
AUZ28
Oct 3, 2015 06:28 PM
mfp189
Sep 27, 2015 09:25 AM
