I need help with my starter....
Old Nov 15, 2000 | 04:31 PM
crazeinc's Avatar
My starter is clicking everytime I turn the key. Does that mean it's: dead, cable loose, or something else?
I'll tell you everything I know. About 8 months ago my starter died, but I found out it was just a loose cable so I haven't had a problem with it since. It's the stock 350 starter as far as I can tell, so I'm sure it's probably its time if that's the case. Up to the clicking it was cranking extremely slowly. I did jump the battery for a while, but it refuses to hold a charge above 8 volts. (The battery is 2 months old, but I haven't driven the car more than 10 miles in the last 5 months)
The reason why I don't think it's dead is because like I said above, I don't ever drive the thing. Haven't used a full tank of gas since June, so the starter has had it easy. Do they just go dead even if they're sitting there?
If it is for sure dead, I want to get a nice Aftermarket mini high-torque starter because I do have Hooker LT headers, so the more I can keep the starter away from the headers, the better.
Thanks!
The '82Z
Hugger Orange
383 4 bolt main
3000 lbs
Bad cornering
NOS Sportsman Fogged
10 bolt braker
Coming to a street near you in the spring...
The car's website
[This message has been edited by crazeinc (edited November 15, 2000).]
Old Nov 15, 2000 | 04:35 PM
ede's Avatar
ede
sounds like the starter. best to take it some where to be tested before you tear into the car and remove or replace good part.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 15, 2000 | 04:38 PM
crazeinc's Avatar
how am I supposed to get it tested if I can't start the dang thing?
Old Nov 15, 2000 | 10:47 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Ya take the starter off the engine and take it somewhere (parts store) and get it tested. They'll tell ya if it's good or bad...
Old Nov 15, 2000 | 10:55 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
If the battery won't hold a charge over 8 volts, I'd be having it tested! Then if it doesn't start, the starter is probably bad. Sitting around will let the battery drain, but not usually kill the starter.
Old Nov 15, 2000 | 10:57 PM
91 RedBird's Avatar
It's the battery
Old Nov 15, 2000 | 11:21 PM
crazeinc's Avatar
I think it's the solenoid...that battery is practically brand new and it's never been a problem.
Old Nov 15, 2000 | 11:24 PM
91 RedBird's Avatar
Swap out another battery and see if that makes a difference. If it doesn't, then you knoe to go in the area of the starter.
sidepipe87
Mar 31, 2015 10:32 PM
Ticeblue
Apr 4, 2011 02:18 PM
Demo77
Mar 26, 2011 06:23 PM
BluFBdy
Nov 3, 2010 12:37 PM
Demo77
Jul 26, 2010 02:34 PM
