305 to 350?
Old Sep 14, 2003 | 09:22 PM
Acidtalons's Avatar
305 to 350?
Will the crank and rods of a post 87 roller 305 work in a post 87 roller 350 block?
Old Sep 14, 2003 | 10:46 PM
darbleinad's Avatar
Car: 84 Trans Am
i was under the impression that a 305 crank would not work in a 350 block because of the counterweights on 305 crank were designed for a 305, not a 350.
i think the rods will work, but often 305 rods are thinner/weaker, so they would not be the best choice.
Old Sep 15, 2003 | 06:23 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
My machine shop as well as many people on here have stated that 305 and 350 rods are the same.
Old Sep 15, 2003 | 07:51 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Most 305 rods are thinner / weaker; and the crank (although the same casting as a 350) is balanced differently to match.
You can use the 305 crank and rods as an assembly in a 350, not to be mixed with 350 parts. Of course, you'll have a weaker motor even than a stock 350 short block, let alone anything good.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
