what do you think of this setup?
Old Sep 16, 2003 | 03:18 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
87 4 bolt 350 bored .060 over.
041 heads
LT4 HOT cam
about 9.5-10:1 compression
edelbrock performer intake and 600cfm carb.
1.5" headers
trans is th2004r i'm going to have rebuilt and strengthened.
it has a 3.23 10 bolt rear i havn't decided if i need something stronger.
how much hp and trq do you think this would make? also, do you think i could get over 15mpg? thx
Old Sep 16, 2003 | 05:55 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
looks common, wouldn't run the 1.5 inch headers though. should make a bit over 300hp.
Old Sep 16, 2003 | 09:04 PM
TheViper's Avatar
Car: '84 Z28
do you think the 1.5" headers woud hurt it that much? right now it has a 2" after the Y(its more than .5" smaller than stock) but every shop i go to tells me I wont feel a difference with a bigger one. i also put a fuel pressure guage in the O2 sensor bung and reved it in park to about 5500 and it went to 7-10 psi which is a lot for exhaust back pressure. it will probably go up a lot more when its driven. at idle it fluctuates between 1-2. what do you think?
Old Sep 17, 2003 | 11:27 PM
zippy's Avatar
Engine: 5.3L
i would say at least 1.625 headers and a much improved exhaust from there back.
Old Sep 18, 2003 | 06:09 AM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Axle/Gears: stock/3.42
throw a set of 3.73 gears and a mild converter(2400-2600) and you have my set up( except i have a 700r4 and edelbrock 750 carb) love it. But if i had to do over i would of ditched the 041's and put a set of vortecs from what i have been told i would of seen about 25-30 more ponies
Old Sep 18, 2003 | 06:36 PM
TheViper's Avatar
Car: '84 Z28
whats the highest compression i could run with that cam on 93 octane running around 180*?
i guess my best bet with the exhaust would be to get a set of hedman headers and y-pipe since i already have a 3" catback.
Old Sep 18, 2003 | 09:27 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
im using the comp cam extreme energy 274 and 10.25 comp timing set @ 16 btdc and it runs great w/o any problems on 93 octane
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
