Problem with trunk!!
Old Nov 17, 2000 | 03:52 AM
Sami Kaukasalo's Avatar
I have this annoying problem with my car's (-87 GTA) trunk. When I turn the key in trunk's lock, trunk's "motor" pushes 'door' 3cm higher and lock opens. When I close 'door' it goes lock and that "motor" should pull 'door' in but it often stays up. So it's like locked but not fully closed. It used to go in on its own after 1-10hours but now it has been "not fully closed" for 2 days. I checked the wires and all should be ok, but still.. it doesn't work properly. HELP!!
-problem solved 20.11.00- I cleaned every part from that mechanism. I don't know was it stuck because of dirty parts but it seemed to help.
[This message has been edited by Sami Kaukasalo (edited November 20, 2000).]
Old Nov 17, 2000 | 09:45 PM
Andy89RS's Avatar
My guess is your hatch is putting enough weight on the latch to prevent it from coming up fully. Until the latch is in the full up position it won't retract. Next time you open it, look in the latch and press the small button in there. You'll know you have the right one when the motor starts moving the latch. Once the latch is fully up it'll stop on its own and be ready to pull the hatch down. Second possibility: The motor assembly is really dirty and just doesn't have the strength to pull the hatch down. If the first suggestion got you nowhere, try putting some pressure on the hatch to help the motor pull it down.
Old Nov 17, 2000 | 11:05 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
It wouldn't hurt to always give the hatch motor a little help. As notoriously weak those plastic gears are, the less work they have to do the better.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 160,000 miles, K&N filter
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
