Non GM -- MOPAR-- What do you guys think on this engine
Old Nov 12, 2000 | 09:11 PM
Stell1579's Avatar
i rebuilding the 318 in my 74 charger. now
its a 318 2bbl from factory rated 150hp
i am going to do this, the 318, edelbrock preformer intake with carter 625 elec choke 4BBL, carter 7psi fuel pump, 2100 stall converter(maby), edelbrock cam int/exst lift 0.420 int/exst dur 204 deg @ 0.050 , stock
heads w/ edelbrock valve springs to match cam
anything else i have missed? and what kind of power should i have, i want this to be streetable (able to cruise the highway and some stop and go)
thanks
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch, Relocated MAT, Cold Air
Old Nov 12, 2000 | 10:03 PM
David Trimble's Avatar
Might want to go over to www.moparts.com and bounce it off the guys there to get a more educated opinion than I can give. But it sounds like a pretty decent setup to me.
[This message has been edited by David Trimble (edited November 12, 2000).]
Old Nov 12, 2000 | 10:11 PM
mtx28's Avatar
how did you wander over hear mr. mopar? wish i could help, but i have no knowledge on mopar motors
Old Nov 16, 2000 | 08:57 AM
jrr's Avatar
jrr
Sounds like a winner! 318s have always been a little weak in off-idle torque, though. Even the so-called Magnum 318s feel a little weak from a stop light. 318s are best once they get moving. That 2100rpm stall converter ought to help.
As with any custom build, don't get discouraged if it doesn't do what you want right away. Half the battle is dialing in the right jetting for the carb and the right mechanical/vacuum spark advance curves.
IMHO, once it's all dialed in, I don't see why you couldn't get 200HP at the rear wheels while burning 87 octane rotgut. Of course, I'm assuming that it has an 8.0:1 CR which was common when your 318 was built.
Old Nov 16, 2000 | 04:20 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Why not build a 360?? Would cost the same???
-Auggie-
Old Nov 17, 2000 | 11:23 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
I've got a set of headers new in the box to fit that car. $60 plus shipping if you want them.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 160,000 miles, K&N filter
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
